removing oxidation/corrosion?
Old Apr 16, 2010 | 10:12 PM
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
I have a TBI injector "cradle" that needs to go in, there is oxidation on it, I cleaned the outsides, but how to clean out the inner fuel passages? To get the corrosion out. Any sprays? these are made of Aluminum aren't they?
this is the part that fuel lines connect to. Both injectors sit in this piece. The fuel meter sits on top
Old Apr 19, 2010 | 05:11 PM
Camarillo's Avatar
Car: 1990 RS Camaro
Re: removing oxidation/corrosion?
Old Apr 19, 2010 | 05:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Use a magnet to see if it's aluminum. Aluminum doesn't rust, it just corrodes, but it won't hurt anything.
I don't mess with TBI, so I can't tell you what material it is.
You can soak it in a phosphoric acid wash to get the rust of the tube, but why would there be rust inside a fuel line?
Old Apr 22, 2010 | 11:34 AM
serpentracer's Avatar
I found something that makes aluminum look like it just came out of the mold.
acid wheel cleaner. I put it on everything that has that white scale on it and it took it all off. but you need to be able to wash it off with water.
a water soaked rag would also work.
but it makes aluminum look fantastic. especially the A/C hoses etc. they look really bright and brand new.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
