1985 trans am 305 tpi have to pump the gas to start it
Old Apr 19, 2010 | 07:52 PM
sammartin1980's Avatar
Car: 1985 trans am
Transmission: auto
Axle/Gears: 373
i have a 1985 trans am with a 305 tpi.i recenlty changed the fuel pump,fuel filter,fuel injectors,spark plugs and wires.but i still have to pump the gas like its carborated.i know i shouldnt have to pump the gas with it being fuel injection.can anybody help me on this??????oh yea i have also put a new distributor and roter button in too.
Old Apr 19, 2010 | 10:24 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: 1985 trans am 305 tpi have to pump the gas to start it
On the TPI cars, while cranking and the gas pedal is pressed down, it cuts the 8 injectors off to prevent flooding.
You could have a leaky cold start injector, which with the other 8 injectors firing might cause flooding.
Now, if it takes the same amount of cranks and pedal pumping to start each time it might be a bad cold start injector or Cold Start switch.
Old Apr 19, 2010 | 11:07 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
im having a similar problem where is the cold start injector/switch
Old Apr 19, 2010 | 11:20 PM
Zepher's Avatar
Cold start injector is on the drivers side of the intake. It is an odd looking injector that has a metal line going to the back of the fuel rail.
the Switch is located on the front of the intake manifold underneath the throttlebody. It has a connector that looks like the same one on the Injectors.
Old Apr 20, 2010 | 10:28 AM
Car: 1985 trans am
Transmission: auto
Axle/Gears: 373
thanks.i knew it had the cold start injector but to be honest i never thought about it causeing my problem.which one would you guys change first.the injector or the switch?
Old Apr 26, 2010 | 04:32 PM
Car: 1985 trans am
Transmission: auto
Axle/Gears: 373
hey i changed the cold stat injector and that was the problem.im now loking to port my plenum.anybody have any ideas?should i port the 305 or should i just get a 350 block and bore it instead
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
drathaar907
Aug 10, 2015 07:44 AM
drathaar907
Aug 6, 2015 04:20 PM
