Oil leaking on exhaust y-pipe
Old Apr 20, 2010 | 04:11 PM
Firebird Mess85's Avatar
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
I was under the car today trying to see how I'd line up the new exhaust if I did it myself and I notice there was a large wet spot on the underside of the y-pipe after it connects by the passenger tire. After touching it, it seems like oil and seemed to be fresh being that it was wet.
I'm confused if it is oil how that would happen? Anyone else have this happen? Rear main seal?
Old Apr 20, 2010 | 05:56 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: Oil leaking on exhaust y-pipe
Odds are the oil is leaking onto the pipe further up and just collected there as it is a low spot. Look for any places around the back of your engine that look oily... could be coming from just about anywhere.
Old Apr 20, 2010 | 06:59 PM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
yeahhhh what he said
Old Apr 21, 2010 | 07:48 PM
I can't see sh*t back there. There's way too much packed in there for me to look at all.
Old Apr 21, 2010 | 07:58 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Most likely, its coming from either the valve cover gasket, the intake manifold gasket, or the oil pressure sender.
Old Apr 28, 2010 | 09:31 PM
Well I replaced the oil pressure sender last month and rechecked that to make sure there was no oil and there isn't.
I have smoke coming from the passenger side and that's where on the y-pipe I saw the oil so it makes sense that it's leaking on that side. I can't see much of anything with the A.I.R. equipment there. Is there a trick to finding the leak without a lift?
Old Apr 28, 2010 | 09:35 PM
84z .....'s Avatar
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
if mine dont drip one drop a week shes not runnin right
xxx3man`
Sep 23, 2015 10:37 PM
downsouthboy
Aug 29, 2015 11:29 AM
Out-Cast
Aug 22, 2015 07:49 PM
Navy8125
Aug 21, 2015 09:32 AM
drathaar907
Aug 6, 2015 04:20 PM
