running bad with est pluged in.
Old Apr 21, 2010 | 02:56 AM
L0tuS's Avatar
ok iam having problems with my 91 305 tbi. the motor was just rebuilt all stock. it will start up and idle fine with the est wire disconnected, but once i plug it in it pops alot rpms every where barely stays at idle and when i put the timeing light on it the mark is bounceing aroung on the timeing flag. then just dies. all the sensor have been replace except for the knockand the ones on the throttle body. any ideas??
Old Apr 21, 2010 | 03:59 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: running bad with est pluged in.
I had an issue like this once and it turned out to be a bad ECM.
Old Apr 21, 2010 | 04:06 AM
L0tuS's Avatar
yea i have been thinking about that, but would it really just stop working like that??
Old Apr 21, 2010 | 04:19 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
When I got my car it had that exact problem. After checking everything I tried the ECM and its worked ever since.
Old Apr 21, 2010 | 05:43 PM
bcmag's Avatar
as weird as this may sound ive seen bad pickup coils in dist cause same issue signals too weak to run on est but fine running off base timing in module.also since you just put motor in make sure ALL ground are hooked up and tight.
Old Apr 21, 2010 | 11:06 PM
L0tuS's Avatar
i replaced the pick up coil and checked the ground all are good, guess ill try the ecm next
Old Apr 22, 2010 | 09:31 PM
L0tuS's Avatar
replaced the ecm and it still doesnt work WTF!!
Old Apr 27, 2010 | 11:06 PM
L0tuS's Avatar
if my timing chain was like a tooth off could it do this?? no mater how long it runs it still wont pop a service engine light
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
BurlyChev
Aug 16, 2015 09:08 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
Bradsaundry
Aug 12, 2015 12:34 AM
