roller cam conversion?
Old Apr 21, 2010 | 01:46 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
whats the cheapest way to retrofit a non roller block?
its just a cruiser, no serious power here.
i heard somewhere that you can use some GM V6 lifter set?
Old Apr 21, 2010 | 03:44 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Re: roller cam conversion?
Curious also.
Old Apr 21, 2010 | 04:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The cheapest way is to buy a roller type block.
Old Apr 21, 2010 | 07:10 PM
tater's Avatar
Transmission: TH350
That sucks! On Fords, you can just drill and tap for the "Spider" and use a factory set up dog bone lifter holders and roller lifters. All of the 302 blocks are the same from '68 to '95. Sometimes I miss my Mustang.
Old Apr 21, 2010 | 07:19 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
kid's right.
Old Apr 21, 2010 | 11:39 PM
redcorvette's Avatar
Car: 85 vette
Engine: 427 SHP block,AFR 210,MiniRam
Transmission: TKO 600
Axle/Gears: 3:07
The cheapest price I have seen for retrofit hydraulic roller lifters for a sbc is $299
http://www.competitionproducts.com/H...uctinfo/91164/
Or for $499 a cam and lifter kit.
http://www.competitionproducts.com/H...info/CL110265/
Starting with a roller type block is cheaper.
Old Apr 22, 2010 | 04:18 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Mmm from what I recall building fords, you couldn't retrofit a non-roller correctly because the lifter bores were shorter on non-roller blocks.
Maybe there's a way around that I knew nothing of, but I seem to recall the only option being buying a friggin expensive custom 'short' cam.
Old Apr 22, 2010 | 04:35 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Ignore Grumbles, there's no problem ( other than cost ) with using the Howards retrofit lifters, which are $269. There's no such thing as a "short" cam.
Old Apr 22, 2010 | 07:34 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I think grumbles was talking about fords in response to tater's post
Old Apr 22, 2010 | 09:03 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I do plenty of SBF v8s too. with those, you don't need an '85 up block to use the factory roller lifters, but even so, they use the same cams as the '85-up blocks.
Old Apr 22, 2010 | 01:30 PM
3rdgenmaro's Avatar
Car: 88 IROC
So you slum it up alittle sometimes huh. j/k
Old Apr 23, 2010 | 08:11 AM
Grumbles's Avatar
Shrug. I haven't bothered with Ford motors since my first car which was quite a while ago. I remember looking up retrofit options and finding out there basically were none. If you know how to retro a factory Ford flatty block please do fill me in, I have a buddy building one as we speak.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
