Why can't Roller Lifters be used on a Flat Tappet cam?
Old Apr 22, 2010 | 02:23 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
School me.....please.
Old Apr 22, 2010 | 04:34 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Why can't Roller Lifters be used on a Flat Tappet cam?
because the peak on a flat tappet cam is too sharp. it would beat the roller to death.
Old Apr 22, 2010 | 04:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The heal of flat tappet cams have a slight taper on them to "spin" the lifter to prevent wear. Roller lifters require a flat lobe.
The contact characteristics of the two types of followers require completely different lobe shapes to produce the desired valve motion. It's all in the kinematics.
Old Apr 22, 2010 | 08:42 PM
tater's Avatar
Transmission: TH350
Ok. That makes sense. Always wondered why.
Old Apr 22, 2010 | 09:17 PM
one92rs's Avatar
Car: SOLD!!!!!
i thought that a roller lifter was allowed steeper lift patterns than the flat tappets.
Old Apr 23, 2010 | 06:22 AM
Damon's Avatar
They can, but the whole way the lifter interacts with the lobe is different. The afore mentioned part about flat tappet lobes having a taper to spin the lifter, but also that a lobe is interfacing with a round surface instead of a flat one makes the shape of the lobe needed completely different to get the valve accelerating and decelerating at the right rates at different points in the lift curve.
Old Apr 23, 2010 | 09:29 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The advantage of roller cams is more aggressive ramp rates and the valve is held open farther, longer. Beyond the fact that it just wont work, it's kind of pointless to bother. Youd just get the same flat tappet grind with a bunch of extra valvetrain weight.
Old Apr 23, 2010 | 03:50 PM
five7kid's Avatar
Not really. As mentioned, the lifter interaction with the lobe is completely different, so a roller lifter on a flat tappet lobe (ignoring the taper issue) would be an absolute dog. Early lift would be practically non-existent.
Old Apr 23, 2010 | 07:43 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Old Apr 23, 2010 | 08:23 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
just to make it clear, the polished looking one is for rollers the dull one is flat tappet
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
