Engine backfire & hesitation when revving
Old Apr 22, 2010 | 09:05 PM
DanJz's Avatar
Car: 92 Formula 350
Transmission: TH700R4
Axle/Gears: 3.23 posi
Hey everyone
I went home from school the other day for a few hours, just to finish up my headlight rebuild, which I finally completed and now have fully functioning headlights again.
So, upon completing the rebuild, I started the bird up and let her warm up for a while, and then, just because I love to hear that L98, I gave her a few nice revs. I noticed that when I rev it up, if I rev it up a good bit and then let off the gas completely, the exhaust will backfire and pop and stuff. It will happen every time, and it has happened consistently over the winter, that I've noticed. Only through the exhaust from what I can tell, I don't think its ever backfired through the intake. At least, I certainly hope not!!!!
Now, I personally think that it sounds kind of cool lol, but I know from quick internet browsing that it's possible that it could mean that the engine has a lean condition and needs to be retuned? I saw that on an LS1 forum, but I have an L98, and I was under the impression that the car's computer was supposed to do all of that stuff automatically lol.
So, my question is, is this most likely due to my needing a new exhaust? I do have an exhaust clamp holding one section together, so it's possible that there are air leaks and I'm told that this could cause backfiring.
On another note, I also still notice a slight hesitation when I step on the gas, if it means anything. Not normal, gradual acceleration. I mean when I really step on the gas to accelerate hard, or, if the car is parked, just to give the car a good rev. It's not like instant throttle response, it takes a second or two for the engine to "catch up" to my foot stomping the pedal, if that makes sense. It's hard to explain. The car runs fine when I drive, drives perfectly normally, no stumbling or anything, it just has this hesitation when I step on the gas hard, and backfires when I let off the gas after stepping on the gas hard lol. Not sure if the 2 are related, but who knows!
Thanks!!
DanJz
Old Apr 23, 2010 | 09:48 PM
DanJz's Avatar
Car: 92 Formula 350
Re: Engine backfire & hesitation when revving
bump
Old Apr 25, 2010 | 04:37 PM
DanJz's Avatar
Car: 92 Formula 350
anybody?
Old Apr 25, 2010 | 09:02 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
take a timing light to it. from the sounds of it, its off.
Old Apr 25, 2010 | 09:12 PM
joe2844's Avatar
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
i would also check tps voltage
Old Apr 27, 2010 | 03:57 PM
DanJz's Avatar
Car: 92 Formula 350
thanks guys, I'll have to give those a shot
Old Apr 27, 2010 | 04:45 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
So is it a like a pop pop pop pop when you let off the throttle mine did that when the cat converters wear blown out and mine probably damaged the inside of my muffler.
I changed the cats and a lot of that popping went away but not all of it take a temp gun to your cats if you have them they should be hotter on the output side then the input side.
Old Apr 27, 2010 | 04:53 PM
DanJz's Avatar
Car: 92 Formula 350
Yeah it actually sounds just like that.
Now that you mention it, I do believe that the cats on my car are completely shot lol. I used to be able to hear the insides of them rattling around when I was stopped and idling, but now I don't hear anything, so I think I probably blew them out. I plan on replacing them when I get my new exhaust, which might be this summer. I'm thinking a cat-back exhaust system, 2 new cats, and a new y-pipe, and possibly some emissions-legal headers, but we'll see
Old May 25, 2010 | 07:42 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Dan,
Before you go throwing a lot of money at a new exhaust system, I would make sure you have eliminated the more simple and less expensive possibilities. Have you hooked a code scanner/data logger to the car? Maybe try replacing the O2 sensors?
That car had to pass emissions here when I had it, and it passed by a wide margin. That suggests to me that the cats are not plugged or broken, unless they have become so in the time that you have owned the car.
Good luck!
Old May 30, 2010 | 03:41 PM
DanJz's Avatar
Car: 92 Formula 350
Hey Dave!
I actually haven't had a chance to plug the car in and get any codes, but I'll definitely have to give that a shot as soon as I can
Red iroc-z 305
Sep 30, 2015 05:22 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
