What type of rear main seal do you guys use?
Old Apr 23, 2010 | 06:19 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I'm going to put a new seal in since I have the trans out and I have a small leak from it. I see that Autozone has 3 different ones though. 2 are in stock and the "high performance" one is by special order. The instock ones are rubber and teflon. The high performance one is called premium fluoroelastomer. This is for a 1 piece rear main block. Do you guys have a preference as to which is best?
Old Apr 23, 2010 | 06:27 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: What type of rear main seal do you guys use?
if the "teflon" one they refer to is a brownish/tan colored seal, thats the one i got a few years ago when i replaced mine...not a drop leaked since!
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
Street Lethal
Aug 14, 2015 08:25 PM
Leggman1
Aug 6, 2015 04:15 AM
