engine break in question...
Old Apr 24, 2010 | 01:15 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I had to cut my detent cable on the new motor. I need to break in the motor for 20min a 2k rpm(in park obviously), will it be ok with no detent cable to increase the line pressure? thanks
Old Apr 24, 2010 | 04:18 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: engine break in question...
Hmm... interesting question. If you wanted to be absolutely safe without knowing I'd say replace the detent cable beforehand. You may also want to ask in the transmission section of the board, or perhaps call a local transmission shop.
Old Apr 25, 2010 | 11:35 AM
serpentracer's Avatar
I thought that cable is just for the kick down when you floor it so the trans will downshift. everyone I know has always called it the kick down cable.
or are you talking about something else?
Old Apr 25, 2010 | 11:42 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Makes ure you use some break in lube in the oil.
Also, it's called a kickdown cable a lot of times but with the 700r4 it's called the Throttle Valve cable because it works a lot differently on the 700r4 than older transmissions. It controls line pressure in the trans and when it shifts and when it shifts down, and how hard it shifts. If you're at WOT at 6,000 RPMs and it shifts softly you're gonna burn up your clutches.
But anyway my take on it is... I'd just hook it up for the hell of it, since you cant, I woudln't worry about it. There's no load on the transmission. Theres no power transmitted through it. The clutches aren't going to be wearing (Which is the main concern)... So unless Im WAY off base (which is very possible. I went to a T56 just to get away from this crap) I think you'll be fine.
MY87LT
Aug 17, 2015 08:43 AM
happyhapka
Aug 15, 2015 04:42 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
