High idle in park?
Old Apr 25, 2010 | 10:15 AM
Chronic9901's Avatar
High idle in park?
Question: My car which is a 1986 trans am 4bbl idles around 13-15 in park when at op temp, but idles normal 7-8 in drive. What could cause this cause im getting pretty tired of my car lurching forward from park to drive and having to turn it off in drive. Ive had this car for 3 years and have rebuilt and replaced just about everything under the hood, so i dont know if this is just one of those things where it is what is is. I would think it would should idle in park and drive around the same range.
Old Apr 25, 2010 | 06:39 PM
Vader's Avatar
Re: High idle in park?
There is too much idle air for some reason and that needs to be reduced. Some easy things to do are:
Check the setting of the main idle speed screw;
Make sure the high idle cam is completely clear of the high idle screw with the choke open;
Check for any vacuum leaks, including the EGR, PCV, brake booster, intake gaskets, and hoses;
Make sure the secondary throttle plates are closing fully;
Verify none of the throttle plates are sticking in their bores.
db057
Sep 4, 2015 07:57 AM
mdtoren
Aug 23, 2015 12:52 PM
Bryan F
Aug 18, 2015 02:28 PM
mdtoren
Aug 16, 2015 05:45 PM
