Casting number with engine in car
Old May 6, 2010 | 05:07 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
What is the best way to see the casting # with the engine in the car? what would need to be removed, if anything? I cannot seem to see it.
Old May 6, 2010 | 05:12 PM
fljerry's Avatar
Car: 1984 Camaro
Engine: 5.0 Liter (305 ci)
Transmission: 700R4 Automatic
Re: Casting number with engine in car
It should be behind the alternator on the front passenger side of the block.
Old May 6, 2010 | 05:19 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I looked there but didn't see it. My alt is on driver side, My ac compressor was on pass side which was removed and I have the delete pully there. Should I remove that?
Edit: Isn't that where the production date code only is?
Old May 6, 2010 | 05:28 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Its on the back "deck" of the block behind the driver side cylinder head. You'll probably need a mirror and a light to read it. Or you can crawl under the car and get the last three digits of the casting number on the sides of the block. Either side will do. It will take longer to figure out what you've got but it works.
Old May 6, 2010 | 06:02 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
That is the 627 # that is on the bottom of both sides then. The stuff in the way of the driver side is the wiper motor some wires and hoses. I will have to fool around next time I have time.
Old May 6, 2010 | 07:07 PM
87WS6's Avatar
#627 indicates a 305.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
camaro71633
Sep 1, 2015 10:24 AM
MY87LT
Aug 17, 2015 08:43 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
