Looking for pointers: Swap Distributor Cap, Rotor, and Coil 86 305 TPI
Old May 8, 2010 | 06:43 AM
Looksthakill's Avatar
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Hello,
I purchased an MSD distributor cap and rotor, and HEI coil, and I want to install them today. I have never done one of these before. Any pointers from the Forum?
* Also, will I need to reset the timing, or should I attempt to start the car with the same timing settings as before the replacement?
Do share your thoughts. Thanks for reading my post!
Old May 8, 2010 | 08:58 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Looking for pointers: Swap Distributor Cap, Rotor, and Coil 86 305 TPI
Welcome to TGO
Unless you rotate the dist, you wont have to change the timing. The cap and rotor are removed from above without changing the timing
An in-cap coil simply bolts on. A divorced coil will require the mounting rivets to be ground off. New coils almost always come with new bolts to secure to the mount
Once you are done be sure to double check that the firing order is correct. If if start it and it runs terrible, chances are some wires are out of order. Use masking tape and a sharpie before pulling the wires off if in doubt
Old May 8, 2010 | 07:08 PM
Engine: 5.0 LG4
Thanks for the response dude!
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
db057
Aug 22, 2015 08:17 PM
st.evel07
Aug 13, 2015 06:15 PM
