Gas pedal a little sticky at times?
Car: 85 Camaro IROC Z28
Engine: 5.0L 305 (cam) [new engine soon]
Transmission: T5 [new tranny soon]
I'll be driving around, all is good, I'm happy, just cruising, no issues, and then SOMETIMES, when I come to a stop at a red light, my car will stay reving at say 2 grand or 1500rpm or whatever while im in neutral with my foot off the gas idling. Anyone know what the issue is and how to fix it? Whenever it happens, it usually goes down back to normal after a little bit but if I just rev the car once it goes to normal. This a issue I should worry about?
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Gas pedal a little sticky at times?
My car does it too, I dont worry too much.
Car: 1989 Camaro RS
Engine: 305 TBI
Throttle sticking most likely. Spray some carb cleaner around throttle and spray around the butterflies while opening and closing it by hand.
Car: 1986 camaro v6
Engine: soon to be 305
Axle/Gears: someone please tell me
also check the condition of your throttle cable, I had mine start fraying on my old impala and it did the same thing then one day it tried to stay wide open on me because the fray got bad enough
Does your car have a carb or tbi? My carbed 86 IROC had a throttle sticking problem. I found out after some investigating that the air cleaner pan was bumping against the linkage, causing it to stick. I had to shut off the engine when it happened. I didn't call 911 either.
Its carb but I think I've fixed the problem just by spraying it, i also cut the spring and made it shorter, just re bent the hook. I havn't had any issues in a couple days and I usually had it everytime I drove.
1992 Trans Am
05-10-2023 07:19 PM
