'88 TPI 350 Qs
Old May 10, 2010 | 04:43 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
'88 TPI 350 Qs
Going to replace the 305/700r4 with something quick. Found a '88 tpi 350 and trans for $875 with 67k miles still in the car. I hope this is obo.
Are there any crazy issues with this engine? Besides a regasketing and maybe a timing chain, what else should I replace while it's out?
I am hoping this is the L98 engine. I'll be taking the radiator,fans, and anything else of value if he won't come down on the price.
I still need the call the junkyards for later model stuff, but this seems to be the fastest way to get my DD rolling again.
Old May 10, 2010 | 05:28 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: '88 TPI 350 Qs
$875 is very high. $625 would be more like it, if it includes the computer and harness.
You aren't going to like the results if you bolt this to your LO3 exhaust system. So try to get those better exhaust pieces with the engine.
Old May 10, 2010 | 05:32 PM
Car: 1986 Trans Am
Engine: 5.0
Re: '88 TPI 350 Qs
I had planned to bootyfab the exhaust until this winter.
I'm also curious about the HP potential of this engine. Or should I just plan a build using a different block and heads. I am doing research , but surfing is tough on a phone
I am mostly curious about turboing this engine. This from a Irok, so I am assuming it has the L98
Old May 10, 2010 | 06:19 PM
Car: 1986 Trans Am
Engine: 5.0
Re: '88 TPI 350 Qs
Nevermind I found this https://www.thirdgen.org/forums/engi...4-305-tbi.html
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
