how to test msd coil
Old May 16, 2010 | 11:02 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
is there a way to test this to see if its bad?
Old May 17, 2010 | 12:17 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: how to test msd coil
i just sprayed some amonia water to see if any of my wires are arcing out and sure enough once the water hit the coil spark jumped from under the msd wire to the coil. what does this mean the coil or wire is bad
Old May 17, 2010 | 05:59 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
put your tongue on the coil and have a good friend turn the car over for you.... no other then not sure any other ways have you tried calling msd? they may have some trouble shooting for you.
Hotrodboba400
Dec 10, 2019 07:07 PM
MM2Robinson
Oct 1, 2017 09:16 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Johnoooooo
Sep 22, 2015 08:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
