Oil Pump Selection
Old May 17, 2010 | 02:20 PM
89Mustang5.0's Avatar
Oil Pump Selection
I'm about to order an oili pump for my brother's 355.
we're rebuilding it currently, and I was wondering if I should get a slightly higher volume pump. Ive read that if bearing clearances are a little on the loose side, a high volume pump is good. I'm not sure on the clearances yet, but Ive read in order to measure the rear main bore, I need to torque down the pump.
Should I get a standard volume, or upgrade to a 10% or 25% increased volume pump? Would extra flow with clearances on the tighter side hurt anything? Also, with the stock pan, would I have to worry about running the sump dry with a 10% or 25% increase?
Thanks.
Old May 17, 2010 | 11:12 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Oil Pump Selection
I've gone with the Melling 10% pump, and it's good with clearances in the 0.0025-0.0030" range. That's the ideal range for performance builds anyway.
Old May 17, 2010 | 11:30 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
i used a big block oil pump that is converted 4 small block use. i ordered off jegs i think its made by GM performance parts. i never have low oil pressure
Old May 18, 2010 | 10:33 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
+1
The BBC pump is approx 30% higher volume than stock.
High volume pumps produce higher pressures at idle and low RPM, then bypass more oil at higher RPM.
This takes a little more engine power to pump the extra volume, but is not significant.
Oil pumps bypass the oil back to the pick-up tube, so if you empty your oil pan, then it means something else is wrong there.
I have heard this myth before. I think it originated with some engine building shops not wanting to warranty performance engine builds that had high volume pumps and came back with bearing damage.
This story has fooled a lot of people.
If you're pumping too much oil to the top of the cylinder heads in relation to the drain-back capability (drains blocked), then you can indeed run the pan dry. This is extremely rare and generally only happens in racing where high lateral G-forces are involved. They usually run dry-sump systems that avoid this possibility.
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
