Trying to find my engine
Car: 87 Camaro
Axle/Gears: 270
I have a 350 block that I cannot seem to reference the suffix code.
V0512DJS
I know its a Flint Engine around May 12th...just cannot find the DJS portion. I was told it was out of a 95 Impala SS...but I knew that wasn't the case just by looking at it.
I have verified the number numerous times...including removing the alternator.
V0512DJS
Car: 87 Camaro
Axle/Gears: 270
Re: Trying to find my engine
I was trying to find out because I was told it came out of a 96 Impala SS but I know that is not the case.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Is it outright NOT an LTx block? Or is it just a matter of aluminum versus iron heads?
While the Impala SSes were all built with iron heads, that doesn't mean a previous owner couldn't've swapped to the aluminum versions used in F-cars and 'vettes.
If it's outright NOT an LTx block, then look down behinf the driver side head and read the casting number, that'll help us identify it.
Car: 87 Camaro
Axle/Gears: 270
E052 5.7 LG1 SG1 and the big numeral 8. I am guessing it was made May 5 of 1992. The thing that is funny...is that the suffix code of DJS I cannot reference anywhere. Regardless...I was mainly as I said before trying to know so that when I buy parts at the parts store I will know what to tell them. So, for now, I am telling them its a 92 Camaro 5.7 liter V8. Sounds good to me.
Car: 87 Camaro
Axle/Gears: 270
Here it is again....all the numbers I have
8 5.7 LG SG1
E052
638
V0512DJS
14093638
Hope this helps.
8 5.7 LG SG1
E052
638
V0512DJS
14093638
Hope this helps.
Transmission: 4L80E/4L80E
That's the casting number. That is the first time you've provided it. The other numbers are not the casting numbers.
That isn't an LT1. If it came out of a '96 Impala SS, the factory didn't put it in there.
It's a generic 350 block. From Mortec.com:
14093638...350...87-95...2 or 4...Roller or flat tappet cam, one-piece rear seal
I have one in Berlinetta #1. It started off life as a ZZ3 crate motor. I only got the shortblock, but added LB9 roller lifter parts to it.
I bartered another one away last fall that came out of a '92 Suburban TBI. It had flat tappet lifters/cam.
What parts are you expecting to need to buy?
