removing cruise control.
Old May 18, 2010 | 11:07 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
how do i remove all of it their are alot of vacume lines over there and im kindof confused
Old May 19, 2010 | 12:41 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: removing cruise control.
Disconnect the cable to the TB , plug the vac line that comes from the intake and remove everything else that is connected to There is a vac line that runs through the firewall to the brake switch
Old May 26, 2010 | 12:49 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
no theres a vacume line coming from the intake then one going from the cruise somewhere else i cant tell though. does anyone have a vacume diagram
Old May 26, 2010 | 01:35 AM
memjr's Avatar
Car: 91 camaro z28
Engine: 5.0 tpi
vacuum diagrams you wanted sorry they might be hard to read
Attached Thumbnails removing cruise control.-87-iroc-350-tpi   removing cruise control.-87-iroc-350-tpi
Old May 26, 2010 | 02:25 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Did you read what I wrote above?
A vac source from the intake and a vac release line through firewall to brake switch
The vac source line should be T'ed of the line from intake to vac canister
Old May 26, 2010 | 01:00 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
do i need to plug the large vacume line that goes to the brake switch through the firewall. i did read just didnt really understand and wanted to see where everything geos to
Old May 26, 2010 | 06:41 PM
bonesbrakr's Avatar
Just pull the T connecting the vacuum from the intake and get a connector that only connects the intake to the vacuum canister. If you want to pull the hose going into the fire wall also like I did then do so, cap the vacuum line under the dash, and get a 1 1/2 inch hole plug and insert in hole in firewall. rest should be common sense.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
