Torrington Bearing and Gear Drive for street use?
Old May 21, 2010 | 07:53 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I can't remember if my Pete Jackson Gear drive had a torrington bearing built in on it or not now.... Anyways I don't think I can stand the noisy sound anymore. It's actually louder than my exhaust. I'm thinking of switching to http://www.summitracing.com/parts/SUM-G6700-Q/
Anyone know how much more quieter those are compared to the noisy ones? Maybe I would be better off just going to to a double roller chain.
Can anyone recommend a good timing gear puller? Does the $15 off the shelf AutoZone ones work okay?
Specs:
383 SBC 4-bolt mid 70s block
Solid Roller Comp Cam
Comp Cam 3 piece timing cover
Cam Button with needle bearings built in to prevent walking
Noisy Pete Jackson Geardrive
bolt lockplate
Old May 21, 2010 | 07:59 AM
Engine: 383 SBC
Re: Torrington Bearing and Gear Drive for street use?
Actually I just remembered my cam button didn't fit through the gear drive so I had to take it apart (remove the snap ring on the button) and put it back together on the drive itself. I didn't have to worry about a Torrington Bearing (block protector) that way. Anyways any feedback would be great.
Old May 21, 2010 | 12:39 PM
Guest
Guest
Posts: n/a
IMO the Pete Jackson "quiet" gear drive is anything but quiet. That summit set is probably the same, they're straight cut gears so its not going to be quiet. If you are tired of the noise, buy a chain or belt drive.
Old May 21, 2010 | 12:45 PM
Engine: 383 SBC
I always thought Timing Chains even if double rollers weren't a good idea once around 7000 RPM or above?
Old May 21, 2010 | 10:12 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Double rollers will cut the mustard.
jklein337
Sep 19, 2018 06:23 PM
Reddeath210
Oct 6, 2015 08:20 AM
gwade12
Aug 8, 2015 08:17 AM
