New to the forums, couple questions about a fuel pump replacement
Old May 22, 2010 | 10:28 PM
nhc89firebird's Avatar
Hey there, I just got my 89 2.8 a couple weeks ago kind of as a project car to work on with my uncle, and i wanted to ask a couple questions.
#1. Is the fuel pump located inside the gas tank or outside the gas tank on the 89 2.8?
#2. I was looking at parts online and they said something about needing to replace the wiring harness if I replace the fuel pump, is this true?
#3. Besides dropping the gas tank, what else do I need to do to successfully change it out?
Sorry for the newbie questions, but we all gotta start somewhere huh?
Thanks much!
--Nate
P.S. Sorry if i posted this in the wrong sub-forum but I could find one that would be more appropriate.
Old May 22, 2010 | 11:58 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: New to the forums, couple questions about a fuel pump replacement
Thanks much!
--Nate
well first thing to do is stock up on some tylenol or advil..
you will have to drop the tank, but first you will have to drop the rear end, and you will have to either move or drop the exhaust as well... all this is in order to be able to drop the tank...
Old May 23, 2010 | 06:23 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
You dont need to drop the rear, Ive removed the tank more than once and the rear has never been dropped. If you replace the pump with a stock replacement, it should be plug and play. To get the tank out you need to remove the black plastic from under the filler door, its just held on with 3 screws. Then jack the car up and remove the exhaust where it goes over the axle and the muffler. Then you remove the heatshield (if its still there). Then you remove the panhard bar and other support bar for the rear. Then you pull the 2 support straps, and bend them out of the way. then you start the fight with the tank. I always wind up having to bend the filler neck to get it out, but as long as its not rusted through and you dont just hang on it, you can bend it slowly without issues.
Old May 25, 2010 | 04:36 PM
firebirdland's Avatar
Car: 91 ,82 trans am 79 t/a
I was wondering, do they sell an under hood replacment fuel pump for our cars, or do we have to use the intake one.
Old May 25, 2010 | 05:03 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
regardless, if it's busted, you will "HAVE TO" remove the tank... even if you just install an inline fuel pump in place of the in tank, you will have to remove the old pump from the tank, otherwise there will be an obstruction in the flow of fuel...
Old May 25, 2010 | 05:33 PM
I put a carberated 2.8 in a 86 comaro once,i just unplugged power to the intank pump, and the motor ran fine with its mechanical pump. since this worked, i was thinkin maybe an aftermarket 'under hood' pump might do the trick. the reason i'm wonderin is because my pump seems to be dieing, and i dont want to drop the tank.
Old May 25, 2010 | 07:32 PM
Thank you very much guys, if you have any more tips or advice it would be greatly appreciate.
Old May 25, 2010 | 09:40 PM
travis401's Avatar
Car: 91 Camaro RS
It might work, but the extra strain on the new pump pulling fuel through the dead pump greatly shortens its life expectancy. Plus you very likely will run into a fuel starvation issue. Just drop the tank.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
