is this large or small cap dizy? (pics)
Old May 25, 2010 | 07:49 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
IS this a large or small cap, ive never actually been told whats what and wouldnt know one from the other, just need to know for my stealth ram
its a 1990 Iroc btw
Old May 25, 2010 | 07:52 PM
joe2844's Avatar
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
Re: is this large or small cap dizy? (pics)
that is the small cap due to the remote mount coil. the big cap has the coil mounted on the cap itself. that will work with the HSR
Old May 25, 2010 | 08:11 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
beautiful, all i needed to know, thanks a ton man!
Old May 25, 2010 | 08:15 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
so is the coil that little unit mounted beside it with the blue wire running to it? What is a good upgrade for the coil that doesnt requre alot of modification?
thanks
Old May 25, 2010 | 09:28 PM
matt1970pon's Avatar
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Axle/Gears: 3.45 g92
aftermarket coil,BUT upgrade cap,rotor,plugs and wires to get the full affect.
Old May 25, 2010 | 10:11 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
yea i was looking at just gettin the MSD basic kind of upgrade peices cap rotor, lines, also got the 6A box
junkcltr
Aug 2, 2019 11:12 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
