oil pressure sensor location!!! Help
Old May 23, 2010 | 04:56 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
ok... I just put a another l98 in my car that someone had in there jeep.... (I spun a rod bearing in my orginal l98) and I didnt notice that they had screwed a cap onto the oil pressure fitting untill I was pluging sensors back up after i had EVERYTHING back together.
I have rounded it off trying to get it loose and it looks like my only option is going to be pulling the intake and drilling/taping the hole witch i DO NOT wanna do...
My question is I was trying to figure out if there was any other location I could use to screw the sensor into?
thanks
Old May 23, 2010 | 04:59 PM
Twin_Turbo's Avatar
Re: oil pressure sensor location!!! Help
Above the filter pad if not already used.
Old May 23, 2010 | 05:21 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
thanks
you might be able to also purchase an adapter from summitracing to hook it up to your filter mounting point..
Old May 24, 2010 | 04:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Old May 24, 2010 | 05:08 AM
wannafbody's Avatar
Car: 88 GTA
sweet thanks guys that worked good....
This motor is not looking so good. I had an adapter for the sensor and hooked it up, has good oil pressure but after I changed the oil and took it for a full throttle run it started knocking bad.
Old May 24, 2010 | 02:09 PM
Twin_Turbo's Avatar
Originally Posted by vetteoz
That's a sweet lookin' motor you have there
89GTAOz
May 16, 2020 09:31 AM
9192camaro
16
Feb 3, 2019 12:21 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
