Car won't start for nothin
Car: 1987 pontiac Trans Am
Engine: 1988 305 TPI
Axle/Gears: 2:73 ... I think
i just finished the t5 swap on my car today and i go to start it up to run through all the gears and i got nothing no lights no key ding nothing. Now it has a brand new battery just bought today, everything for the swap is done except the backup lights are not wired and the center console is off so the window and mirror switch is not hooked up but other than that everything is done. It has a brand new starter and no fuses are blown the car is a 1988 firebird trans am with a 305tpi. All help appreciated thanks
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Re: Car won't start for nothin
Did you change/modify the nuetral safty switch?
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
You already have a thread started on this same topic. Posting multiple threads in the same board on the same thing isnt gonna get you anywhere.
