INTERMITANT SPARK FROM THE DISTRIBUTOR
Old May 24, 2010 | 03:01 PM
85 Z28's Avatar
Car: 85 Z28 Camaro 2011 camaro LS
Engine: 350 Edelbrock Crate bored .60 over
Transmission: 400 turbo
I AM HAVING PROBLEMS MAINTAINING A SPARK FROM MY DISTRIBUTOR, IT A BRAND NEW ON I HAVE GOT IT TO SPARK A FEW TIMES AND START IT WILL START ABOUT 2 TO 5 TIMES AND BE FINE BUT IF I LET IT SIT FOR AND PERIOD OF TIME OVER 20 MINNUTES IT LOSES ITS SPARK AND I HAVE TO TAKE IT APART AND TRY TO GETA SPARK AGAIN ANY SUGESTIONS ON WHAT COULD BE HAPPENING
Old May 25, 2010 | 01:40 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
CAP-SIZE
Wire up a small 12 volt bulb (a side marker bulb works best).
Connect one lead to the coil primary
(the ignition module side not the key side) and the other lead to ground.
The next time the engine refuses to start observe if the bulb is pulsing.
Observe and report.
Happy Racing!
I Didn’t Wreck, The Track Moved
Old May 26, 2010 | 01:00 PM
85 Z28's Avatar
Re: CAP-SIZE
I DID WHAT YOU SAID AND THE BULB IS PULSINF
Old May 26, 2010 | 02:29 PM
NINÅ's Avatar
Transmission: 765R4
CAP-SIZE
OK, if you’re getting pulses into the coil when trying to start, but no spark coming out of the coil, the coil is bad.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old May 27, 2010 | 12:35 PM
85 Z28's Avatar
Re: CAP-SIZE
I PUT A BRAND NEW COIL IN AND I AM STILL GETTING NO SPARK ALSO CHANGED THE CAP AND ROTOR AGAIN COULD IT BE ELSEWHERE IN THE DISTRIBUTOR THE PICK UP OR IGNITION MODULE
Old May 27, 2010 | 12:59 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: INTERMITANT SPARK FROM THE DISTRIBUTOR
is it a procomp distributor? they've had a lot of problems with those.
Old May 27, 2010 | 01:36 PM
NINÅ's Avatar
Transmission: 765R4
CAP-SIZE
The only way the distributor could be at fault is if it was grounding the coil secondary, and you can determine that by removing the center wire from the dist, connecting that wire to a loose plug, alligator the ground part of the plug to engine ground, crank and see if have spark in that plug.
Due to the fact you said you have pulses going into the coil, assuming your observations are correct,
(it’s easy for the novice to mistake the 12 volt fluctuation imposed by the starter motor for pulses) the coil is getting enuff input to render output.
Happy Racing!
Why Did They Say I Was Speeding In The Pits? There’s No Speed Limit Sign
Old May 27, 2010 | 02:55 PM
85 Z28's Avatar
Re: CAP-SIZE
its a accel distributor i can try what you said nina
Old May 28, 2010 | 05:43 PM
85 Z28's Avatar
Re: CAP-SIZE
got my camaro started again it was a bad distributor it had a pad pick up
mrbird
Oct 20, 2015 03:43 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
Lmancha96
Sep 25, 2015 08:11 PM
