low speed cruising sucks
Old May 24, 2010 | 04:51 PM
1988350bia's Avatar
Car: 1988 camaro SC
Engine: 355 four bolt
Transmission: th350
i have an issue when im at cruising speed, mostly low speeds (25mph) where i'll roll on to the throttle and the car sputter then catches up with its self, untill i get onto the throttle harder. when i hammer the throttle it pulls through the rpm's great,which makes me think my timing is good, it only happens when i ease onto the throttle. my other thoughts are edelbrock carb. fuel blend screws on the front of the carb.,fuel pressure or my exhaust is too small.
to tune eddy carbs i have been tought to turn the front screws in one at a time until they affect the idle then back them out one full turn, do the same for both does that sound right?
here are the details of my car.
355 gmpp 2.02 heads 64cc combustion chamber, eddy performer intake and 600cfm carb, msd distributor dynomax headers and single 2.5" flowmaster exhaust, electric in tank pump with regulator set at 5psi,th350 2500 stall, 3.27 9 bolt rear end
Old May 25, 2010 | 01:31 PM
bigzeke's Avatar
Re: low speed cruising sucks
what size cam and are you running a vacuum advance , two very important things to consider
Old May 25, 2010 | 05:42 PM
1988350bia's Avatar
Car: 1988 camaro SC
Transmission: th350
282/292 cam .465/.488 lift and yes vacuum advance, i hooked my vac. advance up to the port to the drivers side port on my edelbrock carb, set the advance (vac. advance disconnected) to 34 degrees btdc and let my idle advance be where it wants, took it for a drive and was having the same hesitation while cruising, i then turned my fuel pressure up to about 7psi and it the hesitation went away for the most part. can i go higher with my fuel pressure? that seemed to have helped.
thanks for the reply any pointers help
Old May 25, 2010 | 06:11 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If your exhaust was too small, it'd be limiting your rpm at higher revs, not affecting moderate rpm like you should have at 25 mph. That's a big cam for a street 350. Vacuum advance should be directly off manifold vacuum. IDK where that port goes, but if the other end is above the throttle blades, don't use it.
Old May 25, 2010 | 06:15 PM
1988350bia's Avatar
Car: 1988 camaro SC
Transmission: th350
yeah the motor was built when i was younger and is over cammed, just working with what i've got now, i do have my vac. advance running off maniflod vacuum. i am just wondering about my fuel pressure now, is 7-10 psi alright?
Old May 25, 2010 | 08:39 PM
MT91Camaro's Avatar
Car: 1991 Camaro RS
Engine: ewww...the 3.1L
Transmission: Not sure. It shifts quite hard.
Axle/Gears: 3.23 8.75" 10 bolt
Another thing to pay attention to is what your distributor is doing. My 74 truck w/ 454 would pull the same stunt. Finally the mechanical advance in the distributor died. Hence, the truck wouldn't even start!
Just something else to check up on.
Old May 25, 2010 | 09:40 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Mechanical advance in the dizzy has nothing to do with starting.
Old May 26, 2010 | 09:10 AM
bigzeke's Avatar
well it has been my experience that with eb carb i think the pass vacuum port is full time and one isnt ,chk eb website they tell you everything about their carbs , another thing i do, in eb carbs there is a counterweighted vacuum assisted air valve that triggers low rpm carb signal , what i do is drill two 1/8 inch hole in each valve to remove weight this makes for better throttle response we havae two 750 s on our indy headed wagon and it sings like fuel injection also get a calibration kit you may need to change needle seat springs to a lighter setup , check their calibration chart online it also will give you the proper jet setup , theres a hundred different things you can do to eb carbs hope this helps you man the cam is fine you just have to get the correct tune up for it , zeke
Old May 26, 2010 | 09:12 AM
bigzeke's Avatar
7 psi may be a little on the fat side for a street car , are you running a regulator and a return line ,just something else i thought of ,zeke
Old May 26, 2010 | 03:22 PM
1988350bia's Avatar
Car: 1988 camaro SC
Transmission: th350
yeah mallory fpr and a return line, i think the calibration kit is my next option, increasing my fuel pressure helped and seems to be acting fine but not perfect, i just got it out for the spring and might be due to sub par gasoline.
thanks guys
any other opinions are appreciated
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Thornburg
Aug 27, 2015 08:28 PM
BurlyChev
Aug 16, 2015 09:08 PM
perZ
Aug 15, 2015 01:17 PM
novaderrik
Aug 10, 2015 12:44 PM
