Starter and Clutch problem
Old May 28, 2010 | 08:14 PM
RJ_Moore's Avatar
Car: 85 SC and 87 IROC Both T-Tops
Engine: 305 V8 H Code and TPI F Code
Transmission: 700R AT/OD and 5 Spd.
Axle/Gears: 7.625
Hey! I have an 1987 IROC Z28 5spd 305 5.0L and the clutch pedal hit the boards and fluid gushed out under the tranny.
Took it to a bunch of Tranny shops, no concensus, ie clutch, release bearing, etc.
Found a shop with reasonable hourly rate, who took it for a ride, before the clutch pedal thing, and tells me not the clutch, not the tranny, not the rear end, maybe u-joints, definately release bearings.
After the clutch pedal boarded, took it to him, and gave him the priority to the clutch pedal, release bearings and a leaking water pump.
When I checked back, he was installing a new starter motor.
Says that the starter wouldn't start, just clicked, and also clicked on a bench test.
Isn't there a clutch/tranny lockout so that the starter engine will only engage when the clutch is engaged?
Anyway, prior to the clutch, starter,water pump stuff, he gave a 10 hour estimate to redo rad coolant system, install center link, y-pipe, catalytic converter, rear tail pipe adjustments so my rear spoiler doesn't go up in flames, install a new release bearing, say $600.00, my parts supplied.
At the end of the day, no universal joints installed, $1735.36.
He installed a new water pump, starter, flushed the coolant system, which makes it the 3rd time in 3 weeks, two from Cdn Tire and then his.
What could make the starter not start? The clutch lockout?
Really need some soothing over on this one.
Richard.
Old May 29, 2010 | 02:42 AM
305blackbird's Avatar
Car: 1987 pontiac Trans Am
Engine: 1988 305 TPI
Axle/Gears: 2:73 ... I think
Re: Starter and Clutch problem
There is a clutch pedal lockout switch but not on the clutch it self he could press the clutch and even if the clutch dosent let the tranny dissengage it should spin but I would bench test it yourself first this seems like shAdy mantinance
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
92camaroJoe
Aug 13, 2015 06:07 AM
rsrmoore
Aug 7, 2015 08:44 PM
