oil
Old May 30, 2010 | 05:38 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
oil
O'Reilleys had a crazy deal on their store brand synthetic oil with a mobil one filter.
The salesman told me their synthetic oil is repackaged Mobil one. Does anyone know if this is true?
Well I did the oil change today. The funny thing is... the computer says I needed 6 quarts of oil. I only needed 4.5 quarts for the change. Does this seem right?
Thanks,
Bill
P.S. My oil level is ever so slightly above the max, but my car burns oil, so I like to top it off. Is this going to flood the engine or cause problems?
Old May 30, 2010 | 06:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: oil
I'll probably get a major bashing for saying this from the more hard-core folks, but IMO, as long as the oil is changed regularly and often (like every 3000 miles religiously), I've never seen any ill effects from even Wal-Mart brand oil.
Now - after saying that, I've never ran Wally World oil in my Camaro - I've always used Castrol - it's just what I started using, and continued using out of habit I guess.
But I run the cheapest no-name oil I can get in my old beater Bronco II, and I've never seen any issues even when I rebuilt the top-end last year - it's got 275,000 miles. But I always change every 3000 miles. And the Bronco rarely sees any highway (ie no long trips) - it just a beater - snow, bad weather, tow boat to the lake, trips to junkyard, etc.
But to me, better money is spent on filter choice, as long as oil is changed often.
Old May 30, 2010 | 06:11 PM
wgripp's Avatar
Re: oil
i usually use mobil one or royal purple
the only reason I got the O'reilly's synthetic is because they told me it was mobile one
Old May 31, 2010 | 01:07 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: oil
http://www.bobistheoilguy.com/forums...Number=1879254
Old May 31, 2010 | 01:28 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: oil
oreilly brand oil is packaged by omni specialty packaging. they are no affiliated with anyone.
Old May 31, 2010 | 01:50 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
Re: oil
Here is another link with some more info about O'reilly's oil.
http://www.oreillylubetech.com/
Old Jun 1, 2010 | 02:29 PM
wgripp's Avatar
Re: oil
thanks guys.
when you change your oil, how much do you have to add? is 4.5 quarts enough? I was expecting 6 quarts!
Old Jun 1, 2010 | 03:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
4 quarts plus what the filter holds.
Old Jun 1, 2010 | 03:36 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: oil
does o'reilly have there own oil refinery ? NO , neither does advance , wal-mart , autozone etc. , etc. . where do they get their oil ? who knows for sure . bobistheoilguy has more info. than one can absorb . the more you ask the more confused one can get . for the most part on a street engine , if it meets all the latest API/SAE specs. it should be o.k. . good luck .
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
