looking for org. article pic 5.7 vortec upgrade
Old May 30, 2010 | 08:05 PM
schnydz's Avatar
Car: 90 Iroc
Engine: TPI 305
Axle/Gears: 3.73 LSD
I found an article on SD's 5.7 vortec head/intake upgrade with hp/tq numbers but the pic is too blurry to read. any chance someone has the magazine and can post a high res pic?
http://www.camaroperformers.com/cama...otographs.html
I'd like to see the graph pic better so I can read the numbers.
thanks,
b
Old May 30, 2010 | 08:23 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: looking for org. article pic 5.7 vortec upgrade
They made 357 hp at 4900 rpm, using the GMPP HOT cam & Edelbrock runners.
Old May 30, 2010 | 08:36 PM
schnydz's Avatar
Car: 90 Iroc
Engine: TPI 305
lol thanks atilla, i saw that too, i was hoping it had a torque curve but i think it's just a comparison to stock HP numbers
Old May 31, 2010 | 04:05 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
no torque curve. But check out post 5 of this thread: https://www.thirdgen.org/forums/engi...st-builds.html
Old May 31, 2010 | 04:45 PM
schnydz's Avatar
Car: 90 Iroc
Engine: TPI 305
how did that motor idle atilla? I need a decent idle for smog. i know you mentioned dropping the CR a little for octane and emissions. also, are the exhaust mounts/ports the same from an original 350 to the vortec heads? I know this is off topic from my original question, but it's my thread, right? lol
Old May 31, 2010 | 07:27 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
It has a very good idle. Sounds about stock.
Whatever headers you were using will bolt up to the Vortecs just fine.
Old Jun 2, 2010 | 07:41 AM
schnydz's Avatar
Car: 90 Iroc
Engine: TPI 305
Cool, Thanks Atilla
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
pimprs
Aug 24, 2015 11:20 PM
jharrison5
Aug 19, 2015 05:53 PM
