Whats the white Valve on sending unit by the Gas tank?
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I'm changing my fuel pump so the tank is out. Now I know the nutted line is pressure, one is a return, one is a vent to the charcoal canister, so I assume the white piece on the remaining line is a one way air intake? I can't seem to draw any air into or out of it. I'm wondering if it has failed and it's leading to pump failures. This will be my 4th pump in 10 years including the factory one.
Car: 1991 B4C-1991 RS
Engine: L98 5.7 TPI-LB9 5.0 TB
Re: Whats the white Valve on sending unit by the Gas tank?
Hey man, Im having pump issues on my 91 RS 305 TBI. When your pump fails, can you jump it to get it started, or does it not run at all?
My car will not start when its cold, but if I jump it, eventually it fires up, then it will start fine as long as its warm. A friend works at NAPA and he thinks my pump is weak and needs replaced. Any help would be appreciated. Maybe some pics of the tank removal if you have them.
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I just saw that your TBI. There may be some differences in the fuel system as I'm EFI but I still dont think it's your fuel pump.
Im pretty sure its fuel related, but the fact that it will run once started has got me stumped. Do you happen to know where the fuel pump relay is located?
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
On the EFI its located on the drivers side FireWall just to the left of the Master Cylinder/Booster assembly.
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
