Stuttering & Code 36
Old Jun 2, 2010 | 01:38 AM
86cotransam's Avatar
Car: 1986 Pontiac Trans Am
Engine: Rebuilt 350
I have had a Check Engine Light on for years that turns out to be code 36 (MAF burnoff). The 86 Pontiac Trans Am, rebuilt 350 TPI, car always ran fine, even with the light on.
A few months ago the car starting stuttering at interstate speeds and under load (i.e. driving hard up a hill). I put on a reman MAF sensor in the past and the code stayed on and the problem did not change. Have replaced fuel filter, O2 sensor, cap, rotor, ECM, and ignition control module. Would a bad MAF Burnoff relay cause stuttering, sluggish acceleration, while driving, especially under load?
The shop wants me to get a reman ACDelco MAF, and not the Bosch. Since the light has been on for ~6 years and the car always ran well, I didn't think the MAF or relay was my new problem. Any ideas?
Old Jun 5, 2010 | 01:01 AM
lopezstud87's Avatar
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
Re: Stuttering & Code 36
did you ever find out what was wrong wit ur car...was it the burn off relay...im getting a code 36 and havein the same prob ur having
Old Jun 8, 2010 | 12:47 AM
Engine: Rebuilt 350
I replaced the MAF sensor burnoff relay. IN the process I found that the plug was full of grease. I don't know if it was supposed to be dielectric grease or something else. Cleaning that out the best I could seemed to help.... The light went off for like 10 starts until.....
it starting acting up on the highway and the light came back on. I have the MAF power sensor on order and will probably try to clean out the MAF burnoff relay better and be sure that the wiring connections are good and tight. It seems to certainly be the wiring....
If you figure anything out with yours let me know...
Until
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
