Yet more engine problems...
Old Jun 6, 2010 | 03:15 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Well, to the people that have been helping me try to get this motor to actually run, thanks. Theres even more problems.
Heres the rundown:
Roller 350 bored 040
Performer intake
Edelbrock 600 carb
New MSD Distributor
New Spark plug wires
New properly gapped ACDelco Spark plugs
Timing is 2*BTDC
Engine has ~300 sputtery, stalling, backfiring miles on it.
1st gear-
Engine has no power, bogs, sputters its way up the RPM's
2nd gear-
Still no power, sputters and fights its way up the RPM's
3rd gear-
NO POWER, engine makes a popping noise from the carb, backfires, then stalls out.
4th gear-
(If you can even get to it) Same as 3rd.
Thanks.
Old Jun 6, 2010 | 08:53 PM
Re: Yet more engine problems...
Anyone?
I am losing my mind at this point.
Old Jun 6, 2010 | 09:12 PM
2 things in the back of my mind, that I keep wondering about:
Vacuum leak at the manifold gasket
Valves are not adjusted properly.
Thoughts?
Old Jun 6, 2010 | 09:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'm no expert at all, but 2* doesn't sound like enough timing advance - mine is set at 11 and I wonder if it's too low sometimes. What are you getting for manifold vacuum reading?
Old Jun 6, 2010 | 10:38 PM
I haven't put a vacuum gauge to it yet, but I plan to if I cant figure this out. The timing is set at 2 degrees before, with the vacuum line unhooked.
Does that sound right?
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
