another hotstart thread
Old Jun 6, 2010 | 05:33 PM
ZedorZee?'s Avatar
Car: 1985 irocz
Engine: l69 5.0ho
Transmission: 5 speed
Hey all just like to hear some opinions on a problem im having. My car starts when cold but when I try to start it hot it cranks slowly very slowly sometimes only for a second and then nothing it wont start at all. When i first got it thought the battery wasnt big enough so i put in a new one. Didnt help. The starter and solenoid are new checked the timing its fine. Now we tried just for the fun to start it with a boost and it cranked faster than ever before. So am I right to think the battery still isnt strong enough , its a 800 and something amp battery. should I consider an optima high amp battery? anyways just want to see what others have experienced.
Old Jun 6, 2010 | 08:52 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: another hotstart thread
If battery, solenoid, and timing are good about the only thing left is battery cables. Make sure they are clean, good ground, and are in good shape.
Old Jun 7, 2010 | 06:05 PM
ZedorZee?'s Avatar
Car: 1985 irocz
Engine: l69 5.0ho
My battery terminals are as clean as can be... still find it weird that it only happens hot. Has annybody else dealt with this?
Old Jun 7, 2010 | 06:08 PM
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
Did you look at the ignition control module? in the distributor, 2 screws, the grease dries out and leads to this symptom. I had a thread, "stall frustration, need help"
Old Jun 7, 2010 | 06:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
New starter n solenoid or a rebuilt unit???
Most are all rebuilt, hard to find brand new off the line, even then it could be a used case.
I had this happen 1 time and it was the solenoid which I only discovered by accident. Its was also new.
I discovered that when I grabbed the cables that hook on the back of the solenoid the end cap on it wiggled. Those things are rebuilt over n over n over and the threads were bugged up where the bolts felt tight, but didn't hold the end cap on tight.
Parts get warm and expand, and walla flaky to no contact resulting in a no start when hot.
And the problem is, those solenoids go right back into the system, Id bet by now 30 folks had fun dealing with the one I sent back and who knows how many before.
Cause when cold, the solenoid will test out as 100% A1 great shape.
Old Jun 8, 2010 | 06:28 PM
ZedorZee?'s Avatar
Car: 1985 irocz
Engine: l69 5.0ho
Well i'll check both those things getting a little frustrated ... What I really dont understand is why it starts perfectly with a boost. Anyways thanks for the help I'll check out your post "stall frustration need help".
Old Jun 8, 2010 | 06:51 PM
ZedorZee?'s Avatar
Car: 1985 irocz
Engine: l69 5.0ho
Hey Camarillo just read your post "stall frustration need help" wondering if the ignition control modual is the same on my carbed L69....also how much does a new one go for ? thanks also anyone else have any Ideas wiiling to hear and try anything. took me a yaer to get it running right this is the last problem I have.
Pac J
May 17, 2020 10:44 AM
Elephantismo
Feb 13, 2019 12:51 AM
355tpipickup
Sep 28, 2015 05:50 PM
Linson
Sep 21, 2015 01:08 PM
