PRESSURE IN THE DIPSTICK
Old Jun 12, 2010 | 12:50 AM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
Transmission: T 56 (converted from 700r4)
Axle/Gears: 4.10 from a 2000 TA
OH OH I HAVE PRESSURE IN MY OIL DIP STICK IS THERE ANY WAY TO ELIMINATE THIS WITHOUT A REBUILD OR REPLACE. THE SMOG PUMP AND EGR VALVE SYSTEM WAS REMOVED COULD THIS HAVE ANYTHING TO DO WITH IT. ANY FEED BACK WOULD BE APPRECIATED THANKS. PS I GET A VERY RICH FUEL SMELL ON START UP AND SOMETIMES HARD TO START AT ROOM TEMP. I AM NOT GETTING ANY BLUE SMOKE OUT OF THE TAIL PIPES
Old Jun 12, 2010 | 01:35 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: PRESSURE IN THE DIPSTICK
check your PCV valve ... stop yelling and if the PCV checks out then you are looking at possible blowby...
Old Jun 13, 2010 | 12:26 AM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Transmission: built 700R4
Axle/Gears: 3.73 posi
Do you have any oil in the antifreeze or water in the oil?
Old Jun 14, 2010 | 10:03 PM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
i checked further into it and found a kink in the tube coming from the PCV which i fixed . i then still had the pressure problem so i replaced the PCV just in case even though it seemed to be working and it fixed the problem , it must have been partially plugged or some thing . thanks for the help and replies
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
BDR
Nov 7, 2015 03:05 PM
Stryker412
Sep 20, 2015 06:59 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
