HELP: Power Steering Leak
Old Jun 12, 2010 | 01:32 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Okay, so I have a power steering leak and I need help. I was having a leak from the high pressure port out the back of the power steering pump, it kept ripping the O-rings on there. Also the pump had a little more play than i would like in a pump, so I decided to replace the pump and the high pressure line from a local auto parts store. Well, I still have the same problem.
Is this a common problem? What are some solutions? I tried not "overtightening" it and it spun loose, then i tightened it more and it leaked, when i took it out it looked like the o-ring was ripped. Im not sure what to do at this point.
Old Jun 12, 2010 | 01:48 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
Re: HELP: Power Steering Leak
You might have a bad motor mount.
I'm pretty sure on the saginaw pumps when the fitting is tight the hose will still move so that rules out the motor mount.
Old Jun 12, 2010 | 01:58 PM
Car: 92 camaro B4C
Transmission: t5
Was it a rebuilt pump or new maybe there's a Burr on the pump side cutting the o ring.
Old Jun 12, 2010 | 02:07 PM
Car: 92 camaro B4C
Transmission: t5
I locked at mine the saginaw pumps are a none moving fitting so you should look at your motor mounts put it in gear and stall it in reverse and drive.
And check for Any burs on the pump side fitting.
Old Jun 14, 2010 | 06:39 AM
Engine: 388 Carb
Axle/Gears: 4.10
It was a rebuilt pump, no burrs on the inside of the pump.
It shouldnt be the motor mounts since the hose is flexible, not a full soild metal line.
This is a really annoying problem.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
bamaboy0323
Sep 3, 2015 06:07 AM
