need brakets for my accesorys
Old Jun 15, 2010 | 01:01 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i want to go with some nice looking brakets for the alt and power steering pump on my v belt 87 iroc. i donot know which to buy for the power steering, some are listed for saginaw pumps. what is a stock pump. what do you guys suggest that will work with the stock style pump
Old Jun 15, 2010 | 09:00 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: need brakets for my accesorys
I went through several different p/s brackets - the only thing that worked for me was the MARCH brackets. I used 20165, but this was for a 1992 p/s pump - depending on which March bracket you use, you might have to change pumps - but the pumps are cheaper than the brackets - the March brackets are pricey at just over $100 each, so pick best match (based on advise from Summit or Jegs or March tech support, then if needed swap pumps.
The p/s brackets are a bit of a PITA - they can send men to the moon but can't make a simple SBC p/s bracket that works You'll need a handful of washers to get it to line up, and you'll have to install/reinstall several times to get it right (changing washer configurations each time).
Alt brackets are easy - hundreds available and most any seems to work (assuming your alt has mounting holes at 12oclock and 6 oclock. I used a Mr. Gasket bracket off the shelf at autozone for $30.
You can see some underhood pics of mine at http://s287.photobucket.com/albums/ll121/jw_baum/92RS/
I have no A/C and no smog pump - just alt, p/s, water pump.
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
Stormshadow GTA
Feb 2, 2002 08:27 PM
yOp 84 Recaro
Carburetors
Nov 22, 2001 07:48 AM
yOp 84 Recaro
Nov 15, 2001 11:04 PM
