Need info on Vbelt to serpentine conversion.
Old Jan 31, 2002 | 11:36 PM
Stormshadow GTA's Avatar
I tried this post earlier but didn't much help.If i change to serpentine do i need new accesories or can i just change the brakets and pulleys on my old ones.I mean AC COMP ,power stearing,water pump,smog,etc.How hard is it to change.
Thanks.
Old Feb 1, 2002 | 02:12 AM
doesn't anybody know
Old Feb 1, 2002 | 05:52 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You'll need all new except for the power steering pump.
Read here.
http://sethirdgen.org/serpentine.htm
Old Feb 1, 2002 | 08:59 AM
GreenProStreet's Avatar
It would be cool to have, but it seems like a lot of work. Do the benefits outweigh the workload? And where in the boneyard can you find a reverse flow pump?
Old Feb 1, 2002 | 10:10 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
You need everything except for the Alternator. You can use your old one if you want, you just have to unbolt the alt face and turn it clockwise/counterclock wise? ( forgot which) so the bolt holes line up with the new bracket.
Old Feb 1, 2002 | 10:43 AM
Engine: 4.0L
Not alot to gain but it sure looks good. Also you don't want a reverse flow water pump, you want a reverse rotation water pump. '88-92 f-bodies used it.
Old Feb 2, 2002 | 06:52 PM
DM91RS's Avatar
Car: 91 RS
It could look like this if you do not need smog or A/C
Old Feb 2, 2002 | 08:27 PM
i'd probably ditch my ac and maybe the smog
3rdgenparts
May 21, 2016 11:50 PM
jrdturbo
Mar 31, 2016 02:58 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
