Anodising Vs. Powdercoating engine parts
Old Jun 17, 2010 | 10:02 AM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
hey guys so i was talking to my buddy last nightand he pulls out this new fuel rail
for his car and it was sweet, anodiesed goldy yellow and nice blue fittings.
anyways im considering doing a few peices under my hood, fuel rails, HSR, ect ect
what are the pros/cons of each? any experience with anodising?
thanks
Old Jun 17, 2010 | 05:44 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Anodising Vs. Powdercoating engine parts
Anodising is more expensive but better.
The industrial equipment I work with, anodising has better corrosion resistance and is necessary on complex parts.
Take a steel hydraulic tube assembly for instance. At either end is a flare nut on the tube. If it were powdercoated the area under the nut would be unprotected.
Pros for powdercoating: cheaper on simple parts that won't have as much exposure to corrosion.
Old Jun 17, 2010 | 05:46 PM
Twin_Turbo's Avatar
If you can get your hands on alodine it leaves a very nice goldish color on bare aluminum.
Old Jun 17, 2010 | 06:25 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
what is alodine?
Old Jun 17, 2010 | 06:28 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
now if i did the plenum and manifold for my Stealth ram do you thin there would be any issues? im assuming the whole whing would have to be done as you couldnt mask off anynthing for a electroplating type process
Old Jun 17, 2010 | 06:34 PM
Twin_Turbo's Avatar
Originally Posted by vendetta
what is alodine?
It's a solution that covers the alu w/ a protective chromium conversion layer.
Typically used in aircrafts, I think aircraftspruce sells it.
It turns out like this, IMO that's ff-in pretty. It's not as durable as anodizing though
Old Jun 17, 2010 | 06:36 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
i actually quite like that, im hoping to do reds and blacks though
Old Jun 17, 2010 | 06:37 PM
Engine: 350 4BBL
You may want to mask off threaded holes (screw a short bolt in them).
Hardest part would be finding a place that can dip them.
There's a place here in Huntsville that anodizes but they do production runs of thousands of identical parts. I doubt they will do one-offs.
Twin_Turbo's Avatar
We can't even get it here anymore..typical european green weenies/tree huggers and eco idiots ruin everything here. So much for my plans to one day build a complete black/gold car in a sort of smokey yunick type way. I was wanting to do that w my 82 trans am 9it's gold/black), I detest gold painted alu parts though.
Old Jun 17, 2010 | 06:50 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
ive contacted a company in Calgary here and they dont mind it at all i gather
Old Jun 18, 2010 | 02:35 PM
Abubaca's Avatar
I think it depends what you mean by durable. Chemicals are one thing, a hammer is another!!!!! I know you can easily scratch anodized surfaces. Powdercoat you can git with a hammer, and if done properly, should be fine. My TPI is powdercoated, and is pretty much as it was the day I had it done. ...and for that matter, every aftermarket suspension piece you can buy is powerdercoated. Sure, it's cheaper, and easier to do one offs, but I think they're totally different processes designed for totally different types of durability.
Old Jun 18, 2010 | 02:37 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
i figured theyd have different use's, i just thought it was a really cool and different look
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
