gas in oil
Old Jun 20, 2010 | 01:03 PM
Racca116's Avatar
Car: '85 Camaro Z28
Engine: 355 carburated
Transmission: TKO600
Axle/Gears: GTA rear, 3.73 posi, hotchkiss
gas in oil
last week i replaced the carb on my 350, and i didnt have it tunned so it was running extremely rich, and i drove it for a few days like that, then i noticed my oil pressure was very low at idle and checked the dipstick, and the oil was thin and smelled like gas. what are the chances that because its running so rich gas is just seeping by the piston rings and nothing is broken or needs rebuilding
Old Jun 20, 2010 | 03:20 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: gas in oil
Does gas get into the cylinders with the car off? Does the car run rough, make any weird sounds? If you're running rich, you're just blowing the extra gas out the exhaust, so it shouldn't be seeping through the ring gaps with it running.
1992 Trans Am
May 10, 2023 07:19 PM
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
