NYS inspection help
Old Jun 21, 2010 | 04:59 PM
firebirdguy1180's Avatar
Car: 1985 Trans Am
Engine: Rebuilt 350
Axle/Gears: 323
NYS inspection help
i need to get my 85 trans am inspected but my brake light on the dash is on . car stops fine been on for months all new calipers , pads , master cylinder . my question is will it pass with the brake warning light on ?? if anyone knows a garage in western ny that could pass me let me know thanks
Old Jun 21, 2010 | 05:06 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: NYS inspection help
thinking really, really, really hard... but I think that light is your hand brake light... if you were to have a brake light it would be an ABS light, which as far as I know did not exist during the 80s... ...
Old Jun 21, 2010 | 05:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
IIRC - the brake light will light up when there's a failure in the system. The "system" will view a major difference in pressure between front brakes and rear brakes - so maybe theres a problem with your proportioning valve.
BUT - easiest fix for the inspection - take the bulb out in the cluster, like a 15 minute job.
Call one station ask ask them about the light -if they say it's a problem, then remove the bulb and go to another station.
Old Jun 21, 2010 | 05:43 PM
Car: 1985 Trans Am
Engine: Rebuilt 350
Axle/Gears: 323
yeah i think i am just gona remove the bulb it annoys me anyways if anyone knows for sure if its passable in nys let me know to save me alittle time
Old Jun 21, 2010 | 06:46 PM
bdle's Avatar
Car: 1988 Camaro IROCZ
Axle/Gears: Stock
this is on a completely different car but my 1990 Honda Accord's brake light is on too, but i didnt fail the inspection. i dont know if this helps, hopefully it did. but im also in a different part of NY and maybe there more lenient then in ur part
Old Jun 21, 2010 | 08:05 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
A brake warning light or a Service engine light on is a automatic
FAIL on a NYS Inspection.
Elephantismo
Feb 13, 2019 12:51 AM
Lbibb
May 5, 2016 12:00 AM
1992Z28!
Nov 19, 2015 07:33 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
bjpotter
Oct 4, 2015 07:48 PM
