Spark plugs hard to reach
Old Jun 23, 2010 | 01:25 AM
jay173's Avatar
So what is the best way to reach and remove the spark plugs on the 305 someone said just go up from under the car?
Old Jun 23, 2010 | 02:19 AM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
Re: Spark plugs hard to reach
Remove all your smog and A\C stuff, and relocate your heater coolant valve thingy. Other than that, I have no clue.
Old Jun 23, 2010 | 07:52 AM
endo666's Avatar
Car: 84 Camaro
Transmission: Stock 5 Speed
I haven't changed my plugs yet but i had to get 6 and 8 from under the car to tighten them up. (whoever installed them originally probably only hand tightened them.)
Old Jun 23, 2010 | 12:29 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
You can get 6/8 from above, you just have to be crafty. You'll have to disassemble your socket wrench, then force the spark plug socket on the wrench once it's in the right area, then remove it. I just did it two days ago to fix a miss.
Old Jun 23, 2010 | 01:01 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Be sure you have a good selection of extensions. I think I use a one inch for the #8 plug. Also a swivel head ratchet is good for getting into the tight space at the right rear.
Old Jun 23, 2010 | 01:17 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
almost all of them are easier through the bottom, # 3,4,7,and 8, the only ones that you can do from the top are 1, and 5 because they're easy to get to, and 2, and 6 because the k member gets in the way from the bottom. the smog system is the biggest issue here, when I replaced mine about 2 months ago, those damn tubes were what slowed me down the most.
Old Jun 24, 2010 | 12:46 AM
jay173's Avatar
Yea so I figerd out how to do them all I had to put a 3/4 wrench on the spark plug socket to remove number 6. I replaced the wires and they where the original wires.
My car now runs smoother, number 8 cylinder had a spark plug wire that was melted in half.
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
db057
Aug 22, 2015 08:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
