Fuel Level Sending Unit Ohms
Old Jun 23, 2010 | 12:42 PM
nezzie09's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
Hey guys, I'm buying all new gauges for my 1987 Camaro 2.8l Sport Coupe and need to know what ohms the fuel sending unit works with.
Sooner than later would be great!
Old Jun 23, 2010 | 12:53 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Fuel Level Sending Unit Ohms
0-90 Ohms
Old Jun 23, 2010 | 01:10 PM
nezzie09's Avatar
Engine: 2.8 MPFI
Thanks a lot.
Old May 31, 2011 | 08:01 AM
Mike M's Avatar
According to the shop manual for my '89 Firebird, 0Ω= empty, 44Ω=half mark, 90Ω=full.
Old Jul 2, 2014 | 09:39 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
question, I have a 1990 Camaro rs, my fuel gauge doesn't work, so I borrowed a buddies spare sending unit, plugged it in outside the tank, moved float to full and my gauge read 1/2, I checked ohms on sender, it went from 20ohms at empty to 115 at full, are these numbers correct or should it be 0 to 90 ohms, thanks for your help
Old Jul 3, 2014 | 02:54 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
IIRC, ALL GM fuel gauges from 1966 and later are 0-90 ohms (empty - full).
If you have it hooked up correctly, it's odd that at 115 ohms your gauge only reads 1/2 tank. One would think your gauge would be pegged over full. Perhaps there's something wrong with both the borrowed sender AND your gauge.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
