Blown Head Gasket?
Old Jun 23, 2010 | 08:18 PM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
Blown Head Gasket?
I bought a 86 pontiac firebird a month ago and noticed that it smokes. The smoke is white and doesnt really smoke at idle, but once you get it up there it releases a storm of white smoke. I also noticed that the engine coolant dropped and had to refill it and the engine had overheated a couple times but does not anymore. I also forgot to mention that the engine misses, but it could just be because the spark plugs are in need of dire change. Any Ideas on what this could be? Blown Head gasket, burnt vavles, etc? thanks for helping!
Old Jun 23, 2010 | 08:34 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Blown Head Gasket?
Sounds like a head gasket. The white smoke you see is actually steam. Look at your dipstick and see if the oil looks milky and look in the radiator to see if you have any oil mixed in the water, both are indications of a blown or leaking head gasket.
Old Jun 24, 2010 | 08:05 AM
MikeSammy's Avatar
The oil doesnt look milky or anything but it does smell weird. the oil smells like chicken being barbecued on a grill if that makes any sense. I do not know if it makes a difference but the enginecoolant level dropped dramatically right after I gave it an oil change and it overheadted a couple times. Oh yeah I do not drive the car. Since I have bought it I only drove it off the trailer into the driveway thats it.
thanks for helping jtsk!
Old Jun 24, 2010 | 09:17 AM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Blown head gasket. Open up the radiator cap and see if you see bubbles and that will confirm it.
3rd gen money
Sep 8, 2015 11:40 PM
earlpote
Aug 28, 2015 10:42 AM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
