cam id?
Old Jun 23, 2010 | 06:08 PM
nickhil2003's Avatar
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
cam id?
I have a cam its brand new that i found up in the loft of my garage, the box dosnt say what brand it is, i would really like to find out what this cam is to see if its worth using in my 350 rebuild.
the numbers from the front of the cam down are
C5, on the samesection the other side reads D5
after the journal it reads C5 on the same section the otherside reads 30
then tworads the very bottom it reads CWC
right before the distributor gear it reads EP6
on the end of the cam it reads 274 a
Old Jun 23, 2010 | 08:25 PM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
Re: cam id?
If you have the box look for the barcode and see if there is a serial number. I had bought 4 cams before 3 from CompCams and 1 from Lunati Cams and they both had serial numbers near the barcode then simply type it into google
for ex: cam xe178654
and search for it that way
Old Jun 24, 2010 | 11:09 AM
Car: 1982 trans am
Axle/Gears: 3.08
Re: cam id?
i tried but i still cant find out what it is. The number is 053059120496
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
