Check engine light on + white smoke from exhaust
Old Jun 24, 2010 | 02:01 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
My check engine light came on last night, what are some things i should check to get rid of it?
I also noticed that every time i start my engine a puff of white smoke comes out of the exhaust? How can i fix this? suggestions?
Old Jun 24, 2010 | 02:22 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
Re: Check engine light on + white smoke from exhaust
mine does the same thing many people say that mine has a bad valve seal since it has a blue tinge to it. if it is all white some say do a compression test. head gasket? or gas?
Old Jun 24, 2010 | 05:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Puff of smoke at startup is normal - like mentioned, it's a valve stem seal leak - it can be repaired without head removal, but it's not a critical thig to do anytime soon.
Engine Codes - get a paperclip and read:
https://www.thirdgen.org/service-eng...ht-error-codes
Old Jun 24, 2010 | 05:29 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Like others said, if the puff of smoke only comes out when the car first starts up, it's just your valve seals. Not a problem if the smoke doesn't bother you.
If the code came on while you were on highways, or any time over 50mph for about 10-20 seconds, and there are no drivability issues after it came on, it's your EGR system. Figure out the code and report back to us though.
Old Jun 25, 2010 | 01:53 PM
Car: 1986 Iroc-Z
Engine: 355
Thats actually exactly how it happened ill look into the codes asap.
Old Jun 25, 2010 | 03:39 PM
ntomsheck's Avatar
Car: 1989 GTA
Oh, if it's your EGR system, there is no dire need to replace it right away. It will help with gas mileage by a point or two, but other than that, the engine will be fine. I ran two years with a bad EGR valve.
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
