how can i get more horse power
Old Jun 25, 2010 | 12:34 PM
spaigo's Avatar
what can i add to increase hp to my 87 iroc it has a 305, headers, new excust and 600 carb
Old Jun 25, 2010 | 12:43 PM
spaigo's Avatar
Re: how can i get more horse power
It is a summet 600 dblpump carb if that helps more
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
There are several ways. Your question is a little on the broad side. You probably need to qualify it by telling us your goals and budget. Your mechanical ability certainly has an impact on this as well as does what tools you currently have or are willing to buy.
Just to name a few of your options:
  • Nitrous
  • Cam
  • Heads
  • Rocker Arms
  • Porting heads
  • Intake manifold
  • Porting intake manifold
  • General tuning
  • Rebuild your 305 (Recommend new heads and cam with this)
  • Stroke your 305 to a 335CID (Recommend new heads and cam with this)
  • Swap to a larger SBC (Get a 350)
  • LSx swap
  • Super charger
  • Turbo charger
Some of these things range from fairly inexpensive to extremely expensive. You can also combine your options here. You could do an LSx swap and then add a super or turbo charger to it. You can also do an LSx swap with cam, heads, and a super charger or turbo charger then top it off with nitrous. Again your budget and mechanical ability comes into play here. If some of your budget involves paying for labor then what you can do for a given amount of money is diminished. If you have a lot of ability or are willing to learn, and this car isn't a daily driver you can go further on the same amount of money.
Whatever you do, I would advise against spending a ton of money on the 305. Anything beyond a cam is just too much money in my opinion. You'd be better off getting a 350 and dropping that in. It will support much more power for the same amount of money spent.
scottmoyer
Sep 5, 2015 09:33 AM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
Chevy3shitty
Sep 1, 2015 02:10 AM
sailtexas186548
Aug 24, 2015 10:11 PM
