350 tpi
Old Jul 4, 2010 | 12:56 AM
1badb1rd's Avatar
Car: 1989 camaro z28
Engine: 412 sbc
Transmission: 350 turbo 4000 stall transbreak
Axle/Gears: superior axles 4.56 gear
350 tpi
I have a 350 tpi in my 89 firebird it has hedman hedders and 3'exhaust and a 342 posi gear.im adding a set of 202 heads and a 287/297,.560/.580 Lift cam and getting it tuned.About how much horsepower will that add.
Old Jul 4, 2010 | 02:46 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350 tpi
Originally Posted by 1badb1rd
a big cam .
Define big cam ?
Old Jul 4, 2010 | 03:00 AM
1badb1rd's Avatar
Engine: 412 sbc
Re: 350 tpi
Old Jul 5, 2010 | 06:12 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: 350 tpi
Did you check operating range of that cam ?
3500 -7000 rpm
Need some much lower gears , hi stall and a lot of compression to make that run in a stockish 350.
Not forgetting a stock TPI doesn't breath over 4500rpm so that gives you a 3000 -4500 rpm operating range
Forget about idle quality
Old Jul 18, 2010 | 09:39 PM
low's Automobil's Avatar
Re: 350 tpi
i have LT1 motor tryin to wire it up can u tell me
Old Jul 19, 2010 | 03:31 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: 350 tpi
Start a NEW question instead of joining in on old ones that have nothing to do with your problem
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
