optimum spark color
Old Jul 5, 2010 | 10:59 PM
LeenMeanAndLow's Avatar
optimum spark color
If everything is working right what color should your spark plug spark be?
Old Jul 6, 2010 | 12:35 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: optimum spark color
What part of the spark plug? There's more to reading a plug than just looking at the color of the insulator.
Start by reading all 5 of these pages.
http://www.centuryperformance.com/sp...ch-spg-26.html
Then read this page
http://www.empirenet.com/pkelley2/sparkplugreading.html
Old Jul 6, 2010 | 07:15 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I didn't go read all that, but the short answer is: It depends. Differing amounts of ethanol in the gasoline makes an easily noticeable difference, but even which refinery it comes from can make a detectable difference.
Old Jul 6, 2010 | 07:44 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
If I am reading the OP correctly, he wants to know what color the spark should be, not the plug.
If so, a good rule of thumb is to make the spark jump a gap of about 1/4". This is easily done by inserting a phillips screwdriver into the end of the ignition wire in place of the spark plug, and then laying it down so that the shank is about 1/4" from a good ground. Obviously, you want to avoid doing this if you have raw fuel and/or vapors present.
Have a helper crank the engine (or use a remote starter switch) and the spark across that gap should be blue. If it is yellow, that indicates a weak spark. Trying the same thing with a spark plug may produce a blue spark, but the gap is smaller, so it's less conclusive. Plugs fire differently under compression.
MM2Robinson
Oct 1, 2017 09:16 AM
camarohelp
Sep 22, 2015 03:19 PM
Linson
Sep 21, 2015 01:08 PM
Jlanz55
Sep 9, 2015 09:09 AM
angel2794
Sep 8, 2015 06:22 PM
