I keep reading thirdgens only came with 153 tooth flywheel but..
Old Jul 6, 2010 | 05:46 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Like the title says, I've read over and over that 82-92 fbody's only had the 153 tooth flywheel. I'll be replacing mine soon and don't want to order the wrong part. My engine(l98) was pulled from an 89 formula and has the staggered bolt starter, therefore being a 168 tooth flexplate, right? Also do I order internal or external balanced?
Old Jul 6, 2010 | 06:20 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: I keep reading thirdgens only came with 153 tooth flywheel but..
So a previous owner changed it. With an automatic, it's no real challenge. It doesn't really matter unless you're trying to use a stock T5 bellhousing. Smaller is better for performance, but the difference is not enough to feel.
Old Jul 6, 2010 | 06:50 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Ok so all that really matters is the bolt pattern and making sure the starter/flexplate match up?
mhatfield 14
Oct 24, 2015 07:48 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
BBSDesigns
Aug 11, 2015 07:39 PM
milk
Aug 10, 2015 06:26 PM
