No crank, good bat, (good) starter, no noise from starter. Help!!
Old Jul 7, 2010 | 04:42 PM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Here's the story. Car started and ran well a few weeks ago. Went to start one day and it cranked but wouldn't fire (ran the car out of gas in the driveway a few days earlier). Put gas in no fire (maybe a random fire once and a while), so I left it. Started troubleshooting and found out my fuel pump didn't prime (pump) anymore. I jumped the fuel pump at the fuel pump relay and it pumped. I went to try and start and it was cranking slow. So i left it for the night. The next day I pulled a plug to **relieve pressure** (that wouldn't matter since its fuel injected) then went to go start it and no cranks at all not even a noise but the dash lights came on like normal (seemed like the clutch wasn't being pressed in).
This is what i know:
Battery at 12.48 volts
Starter turns when jumped with a piece of metal
All car lights and dash lights work and radio
Engine is not seized
No sound from starter at all
This is what iv done so far:
I tried boosting the car with another car
Put the plugs back in
Messed with the relays on the drivers side firewall
Heres what might be wrong:
I was messing with the relays on the drivers side firewall (fuel pump relay).
Any input will be appreciated
Old Jul 8, 2010 | 10:17 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Re: No crank, good bat, (good) starter, no noise from starter. Help!!
The problem was a fuse above the drivers legs. I still have a fuel pump issue. I ordered a new fuel pump relay.. Ill see if that is the problem.
What do you guys think? I jumped the fuel pump at the relay and it pumped. So it must be the relay then right?
Old Jul 9, 2010 | 10:10 PM
Awesome-X's Avatar
Car: 87 Camaro
sounds like it
Old Jul 10, 2010 | 12:10 AM
1990z28's Avatar
Car: 1990 Z28 Camaro
Did you check your fuel pump fuse thats hidden kinda deal. Mine was where the battery is so check there for a plug looking thing that is a fuse before you order the relay. Its worth it to check it since if thats it you spent unnecessary money and still got the problem.
Old Jul 12, 2010 | 08:06 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Yea I know about that fuse I blew it up about 3 times trying to jump the starter. Its in a little sealed canister. I got the relay and its working now.. Now all i need is some more gas i think as it stalls right after starting. Ill let you know.
Old Jul 12, 2010 | 11:50 PM
1990z28's Avatar
Hopefully everything works and it wont stall out I remember mine used to start and stall out a few seconds later because of a module on the distributor.
specialized
Jun 18, 2022 09:26 AM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86Base
Aug 8, 2015 01:34 PM
