sensor location on 350
Old Jul 8, 2010 | 06:28 AM
the gtaman's Avatar
Car: 1989 firebird gta
Engine: sbc 355 hsr 280xfi 58mm tb
Transmission: raptor 700r-4, 2800 stall
can some one post a picture or tell me the correct placement of the sensors,on the bottom of a 89 gta 350. i know knock sensor ,oil pressure switch ,and open hole ?
Old Jul 8, 2010 | 07:45 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: sensor location on 350
You already know where those listed go or you want to know where?
Where is "open " hole?
Knock sensor in drain hole above pan; pass side,
OP switch above oil filter or rear of block behind dist
Old Jul 8, 2010 | 07:51 AM
the gtaman's Avatar
yeah i know where those two go ,but i have an open hole on driver side same location .im thinking the machine shop removed a plug and forgot to put it back.
bamaboy0323
Sep 3, 2015 06:07 AM
Out-Cast
Aug 17, 2015 10:57 AM
Rustyweb7
Aug 9, 2015 03:05 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
